Photoworks 2 material applying to multi configs
Trying to find out if theres a way to apply a photoworks material/texture to all or some of the configs of a part?
In my case, I have a routing duct/pipe that consists of approximately 150 configs, wich again is used to generate ducts and pip configs in the route.
applying materials individually is a pain, so is applying to the routing assemblies every time i make a change in the route. if the material was all set from the start, I would have less to worry about.
is it possible to cabge the default material? This copuld be a temp soulution.
best regards, Bernt.
