Analysis Window
Analysis Window
In CATIA V4.2.2 for some reason the alpha-num window does not come up automatically when in ANALYSIS function.
Can anyone help me to set up CATIA declaration to solve the problem?!
Thank you
Thank you
RE: Analysis Window
catia.ANALYSIS_WINDOW
It can have two values: TRUE or FALSE.
Or simply press key Alt and Plus to bring it up
Alt and Minus to close it down
Cheers. Kennis Tang.
RE: Analysis Window
You also have some option with the /monasc off
If my memory is good...
Eric N.
catiav5@softhome.net
