Fire Flow Requirments
Two methods for computing fire flow that I am familiar with are from the Uniform Fire Code (UFC) and ISO. I am working on a high rise project where the fire sprinkler designers used the NFPA (hydraulic method) for the design. Would it be valid to use the fire sprinkler capacity as the fire flow required for this building? IF we use the UFC method the required fire flow would be substantially higher than the sprinkler capacity even with the credit taken for a fire suppression system. I do not want to underestimate the fire flow needed since we will be using this to design the water mains for this site. I am leaning towards the UFC method since, in my opinion, the fire flow needed should exceed the fire sprinkler demand. It seems to make sense that you would need additional flow from adjacent fire hydrants to supplement the fire sprinkler system . Thank you.
RE: Fire Flow Requirments
CANMAN
