Layer Groups in Acad 2004 Mechanical
Anyone know how to add a layer to a layer group in Mechanical version of AutoCAD.  At one time I had this figured out a few years ago, but now trying to add a new layer that will be used in several layer groups, and I am at a loss.
RE: Layer Groups in Acad 2004 Mechanical
I believe that you type "amlayer" at the command line (one way to start the command) and then select "Layer Group Control" and hit the "CREATE" button.
JRWalker
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
