DC Motor (90VDC & 180 VDC) Wire Color
What is the "industrial standard" wire insulation color for DC motor (90VDC or 180 VDC) leads? I've seen some places that use black and others that use blue. Are both leads the same color? Are the field & armature all the same color? Thanks
RE: DC Motor (90VDC & 180 VDC) Wire Color
See ยง7.6 or NEMA Std ICS1-2000 on wire color coding.
At the moment, after signup, ICS1 is available from NEMA as a free electronic copy.
