Inserting images in LT
Could anyone remind me of the keyboard shortcut to bring up the insert dialogue box in AutoCAD LT 2002 so I can insert a JPEG. I know it can be done but I can't remember how? thank
RE: Inserting images in LT
I'm not sure because I use an older version of light.  When I can do something by selecting buttons but don't know the command, I do it one then hit f2 to see what commands were used.  I then use the same command with a - or _ in front of it to force it to be all text entered.  Then I can usually work it out.
Tim
"IAT"
@ command line will invoke the attach image dialog.
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
IAT does not work. I am running AutoCAD 2002 LT
From < help......   insertobj    brings up a dialog box to insert all kinds of things.. Not sure if it is what you are looking for though.
Attach/insert raster images even in AutoCAD LT (hidden trick).
It is easy to attach raster image files in AutoCAD LT 2002 (2000i, 2000) although it is a disabled functionality.
Start the _IMAGE command to start the Image Manager and press Alt+A keys (English and Italian version only, use Alt+Z for the German, Alt+T for the French, Alt+D for the Polish, Alt+E for the Spanish versions).
hope this helps.
don't have LT to test.
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Ozzy84
Thats the one, thanx
