Hatch problem?
Hatch problem?
Hatch problem?
Every time I updated my view in UG-Drafting section my hatch change to 75 or 135 degree. I want the default to be 45 degree.
I use Preference annotation fill/hatch to set the angle
thanks kth
RE: Hatch problem?
Check to see if you have Assembly Crosshatching turned on in View Preferences.  If you do, turn it off & see if that helps.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: Hatch problem?
Thanks for the tip Tim.
I have tried but it still changes the entire hatch every time the view is updated. It is like this commando is turned on all the time?
