Sum Corresponding values
Hello All,
I have a list of names in one column and several values in a second column.  I want to lookup all occurances of each name in column 1 and sum the corresponding values in column 2.  Can someone please help me with this?
Example
Scott        1
Jon          2
Scott        3
Lookup "Scott" and return 3+1 = 4
Any help is greatly appreciated.
RE: Sum Corresponding values
Have you tried SUMIF?  It seems to be tailor-made for your application.
TTFN
You could also look at Pivot tables if you want an "automaic" sum of all your "labels".
In your example a pivot table would produc a result table looking something like this (you have a add a label in the row above name/values:
Sum of value    Name
    Jon    Scott    Grand Total
Total    2    4    6
or the other way around:
Sum of value
Name    Total
Jon    2
Scott    4
Grand Total    6
Its very easy to costumise and ideal for making summaries etc.
Best regards
Morten
Dear MEM1,
There is a simple solution:
1- Use AutoFilter to filter the data on each name
2- Use the SUBTOTAL function to sum the corresponding data in second column (the AutoSum button automatically uses the SUBTOTAL function if used for AutoFiltered tables.
Farzad
