7075-T79511 Extrusion
Does anyone know where I can find mechanical properties for 7075-T79511 extruded aluminum?  Any help is greatly appreciated.
RE: 7075-T79511 Extrusion
Since this is not a common product, I would contact Alcoa.
Cory
PASiii
I would like to know if you were successful in your attempt to obtain the 7075-T79511 extrusion allowables data? This material is used in the wet areas of the Airbus narrow body aircraft and I too would really like to get my hands on it.
FYI it is my understanding that the static strength properties are very similar to 7075-T6511 extrusion, with better corrosion resistance.
