Iges files from Pro-E
My customer has sent me an iges file and I am having a problem bringing it into NX. This part is kind of a cylinder in shape. There are radii that go around the outside of the part. Instead of these radii just blending the OD with the the top and bottom of this cylinder, it is a torus setting at the intersection.
Are there any settings I can change on my end for a solution to this?
You might ask why I don't delete the torus and add a radius. Well the part is not that simple, but for this question I wanted to put it in simple form.
Dave
Dave
RE: Iges files from Pro-E
If they are on Wildfire, request a Parasolid file.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
enable_parasolid_export YES
Ben Loosli
Ingersoll-Rand
