Temperature Coefficient for Metal Film Resistors
The Temperature Coefficient for Metal Film Resistors defined by manufacturers as +/- ppm.
What is the reason for such definition (what is the physical process for decreasing resistance with increasing temperature)?
RE: Temperature Coefficient for Metal Film Resistors
I guess I never paid much attention to MF but should not the resistance go down with a decrease in temp?
explains why you might get positive or negative TC's for metal film resistors
TTFN
is increasing with T. 2.) The thermal expansion of the substate.
<nbucska@pcperipherals.com>
