Help with dimension.
Our SolidWorks dimensions are using the JIS standard. In our imperial drawings, the inch (") symbol will not automatically be applied to dimensions. They show up when the dimension is set to Feet-Inches. Right now I've been adding the inch symbol to the text in the properties box. I know you can set this up as a dimension favourite but I have to select the favourite for each dimension.
Sean Nutley
Carmanah Design and Manufacturing
Vancouver, BC, Canada
www.carmanahdesign.com
RE: Help with dimension.
Hope that helps.
Sean Nutley
