Cronidur 30 vs 420 SS
Below is a material analysis results and hope someone can help out.
C .30%
Mn .36%
P <.010
S <.001
Si .30%
Cr 12.03%
Ni .08%
Mo .27%
Cu .02%
Al <.01
Sn <.01%
Hardness 34 HRc
C .30%
Mn .36%
P <.010
S <.001
Si .30%
Cr 12.03%
Ni .08%
Mo .27%
Cu .02%
Al <.01
Sn <.01%
Hardness 34 HRc
RE: Cronidur 30 vs 420 SS
I have never heard of Cronidur 30, but the chemistry that you supplied above is super close to AISI 420 SS (with a trace of Ni, Cu, Al and Sn). Could you give more information on chronidur 30? What is the application for this material?
Coka
Here is some information on Cronidur 30. It apparently was developed by FAG and is a high performance bearing steel;
http://www.bardenpressoffice.co.uk/1.html
http://www.bardenbearings.com/PDF%20CD/PB18.PDF
