Section Name Change
Section Name Change
Section Name Change
In creating sections in drawing creation, a section name is required (A, B or whatever).  My problem is sometimes I create a section incorrectly or later decide to delete it, then I can not use that section name again (such as SECTION A), pro/e has assigned that name to something.  How can I delete the section name from the file so it can be reused so I can have a reasonable drawing with views labeled A through Z? Thanks for your help.
RE: Section Name Change
May I suggest you create the sections required in the model.
Can you not delete the sections from the model? X-Section --> Delete (chooose name)?
You can rename an 'unused' section to OLD_A, OLD_B etc.
Hope this helps.
maybe only a drafter
but the best user at this company!
Forgot to mention I am using Wildfire.
Thanks onlyadrafter, that's the ticket.  Just didn't know where to find that command.
We also create sections in the model versus the drawing.
The conflict I have is having the same name used often.  The datum and section can not be A.  We name the section datum plane AA and the GD&T datum plane A.
I haven't ever created sections in model mode.  Seems the problem is keeping track of section names, especially (as in my case) when there are many parts in one multi-sheet drawing (vs one part per drawing).  So far I am having good results in creating sections in drawing mode.  Thanks for the help and advice.
