Menuload - Keeps dropping out.
I've written a new partial Menu, but for some reason every time I start a new session it has dropped out. It loads fine every time, but is gone next time I start.
Funny thing is, it was only an altered .mns file from a previous menu I'd written and that one stays in fine.
I've checked all the file paths, etc have been correctly revised...anything else it could be?
RE: Menuload - Keeps dropping out.
http://www.caddigest.com/subjects/autocad/tutorials/select/parsai_partial_menus.htm
I was just surprised that this is only an edited (and expanded)version of the original menu (albeit renamed) and that one stays loaded no problem.
Anyway, I shall try the suggestions and let you know if it works.
thanks for your replies.
C:\Documents and Settings\%username%\Application Data\Autodesk\AutoCAD 2004\R16.0\enu\Support
After copying it there, load it from this location and then check to see if it stays. G.L.
