cross reference charts
How can I get a chart or table indicating pressure (psi) against ANSI rating (i.e. ANSI 150 = 285 psi)
RE: cross reference charts
Come back with a little more information about what you want the rating on?
It's vessels rating tables (or Charts) used in Pressure vessels (fabrication & operation).
You may have an operating pressure of 1440 psi, so, What is the ANSI rating for that vessel?
SulfaTreat,
You can not specify rating with only pressure. Temperature and material are the necessary information.
ASME/ANSI B16.5 should be your reference.
According to ANSI B16.34, the temperature may be from Standard (or -20 F) up to 1000 F.
The material I'm concerned with is Carbon Steel A105, but the tables should cover all materials (right?).
Thank you very much.
