Firetube two pass heat exchangers pressure drop
Looking for pressure drop readings for exhaust side of two pass firetube heat exhangers in an engine driven waste heat recovery application. Are there any of these type units around Oklahoma, or Texas? Please call 318-686-4709 if you know of these units locations or post them here. I would also want to know engine exhaust flow, incoming gas temperature and outgoing gas temperature as well as the other side process weather making hot water or steam. Need water flow and in and out temperatures, or in steam applications, steam pressure being made and feedwater temperature in. Also need to know number and size of tubes/pass. Type fuel being used in engine is helpful, also.
RE: Firetube two pass heat exchangers pressure drop
Cheers
steve
rmw
Did the evaporator group move to houston as well??
rmw
Did you do much work with them? Do you work with engine heat recovery?
I do currently work with heat recovery, but it is rarely applied on recips. More often with turbines, boilers and combustion related processes.
rmw
