Condensate drain plug
I have found several manufacturer's of drain plugs, but have decided to use one similiar to this one found on Reliance's website:
http://www.reliance.com/mtr/cmdr.htm
This app will be non-xp. I have found a couple of manufacturer's that will make this as a special. I am curious if anyone knows of a manufacturer that makes a plug like this stock. Also, if anyone has information with regards to sizing the exit hole diameter with regards to amount of condensate that may build up. Are there design specifications published for condensate drainage?
RE: Condensate drain plug
http://www.usmotors.com/PB202/PB202_11B_Acc_Mod%20B-E.pdf
http://www.crouse-hinds.com/CrouseHinds/InstallationDocs/IF%20843%20Revision%202.pdf
etc. for mofe info
Is this field-installed stator housing drain for TEFC motor?
Just curious and hoping to learn a little.
