Library Feature Problem
I am creating a library feature and it will not allow me to add a helix to the library.  Has anyone encountered this before?  If so, is there a work around or fix?  I checked to make sure that I didnt have external references that may cause the problem, but I got no where.  Thanks for your help
Brian
RE: Library Feature Problem
The only reason why I think it won't work, is because it's not a true sketch nor a feature. try making a second profile and sweep them together. That should then you could have the user remove the feature and the second profile. They would then be left with just the helix.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
That is what I started out with.  I had my loft created using two profiles and a helix and it would not let me add it to the library.  Then I started investigating why and found I was unable to add the helix sketch to the library.
Do I go through my VAR to do this or straight through SW
