Heavy Oil Pipe Sizing
Are any rules of thimb for sizing pipework for heavy oil applications.
I know that in general liquid flows pipes are usually sized to keep the flow velocity between 2 and 4 m/s. Does this still hold for high viscosity fluids (up to 8000 cP!)
Cheers,
Neil
Cheers,
Neil
RE: Heavy Oil Pipe Sizing
The key link is this one:
http://www.euronet.nl/users/e_wesker/et.html
and a search among the links here should find it. (It may be that it is my machine that is suffering today.)
If i can get it back i will post it here for you.
JMW
www.viscoanalyser.com
eng-tips, Pro bono publico
"Si tacuisses philosophus mansisses"
"If you had kept quiet, you would have remained a philosopher"
