Dimension extension lines....
Does anyone know how to change the dimension extension line offset so that they are closer to the view.
Thanks in advance
Jeff
RE: Dimension extension lines....
Do you mean you want the gap between the dimension leader lines to be nearer the actual entity being dimensioned?
If so I beleive you need to change WITNESS_LINE_OFFSET in the DRAW SET-UP.
Hope this helps.
maybe only a drafter
but the best user at this company!
