How to connect a 6 cables Star Delta motor for a direct start-up
Hello everybody,
a customer of mine has asked me a clear explaination on how to connect a 6 cable Star Delta motor for a direct start-up.
I know how to do it practically but I look for some clear instructions (with drawings?) that might maybe already be found on the net.
Can you give me a hint?
Thank you.
A.
Thank you.
A.
RE: How to connect a 6 cables Star Delta motor for a direct start-up
"Venditori de oleum-vipera non vigere excordis populi"
This is easily solved, just use three copper links or crimped single core cables (large enough to carry the phase current = F.L.I / 1.732) to link out the three sets of motor terminals.
I.E connect:-
U1 to V2
V1 to W2
W1 to U2
Hope this helps?
Alan
http://www.usmotors.com/default_service.htm and see the delta or low voltage connection.
Indeed we DO produce motors... I had just to structure some PPT instructions for my friend...
Well... it took me some time but he thanked me so... I think your help was ok!
Thank you again.
A.
http://www.lincolnmotors.com/pdf/diag.pdf
for the wiring diagram shown on page 261
