ASME B16.5 SAF2205 Flange Ratings
Does anyone have the pressure vs temperature ratings for ASME B16.5 Class 600 flanges made from SAF2205 Duplex Stainless Steel? If so, where can I get a copy?
RE: ASME B16.5 SAF2205 Flange Ratings
MATERIAL 2205 Duplex SS (S31803):
PRESSURE - TEMPERATURE RATINGS
TEMP F -20 to 100 200 300 400 500 600
TEMP C -29 to 38 93 149 204 260 316
For NPS 1/2 through NPS 4 (Full flange ratings per ASME B16.5, Table 2-2.8)
Psig 1500 1440 1330 1230 1150 1115
Kpag 10340 9930 9170 8480 7930 7690
Leonard@thill.biz
www.thill.biz
Thanks for that. I dont have my copy of ASME B16.5 with me. Which B16.5 material group does SAF2205 below to?
The above posting was from ASME B16.5 1998a. Their is a difference between ASME B16.5 2003.
CSGWB (Mechanical) you will need to check both CODE or use ASME B1.5 2003
http://www.gowelding.com/pv/flange.htm
enjoy
Keep the wheels on the ground
Bob
showshine@aol.com
Putting Human Factor Back in Engineering
A: THE ASME LIBRARY
ER
