Changing or deleting fillets on imported model
I've got an imported Unigraphics parasolid model (.x_t), that has fillets. I have to change the fillets from .375 to .188, or delete them and re-fillet. When I try to delete them it won't let me because it's
an imported model, Is there any way to edit these fillets,delete or modify them? Help
RE: Changing or deleting fillets on imported model
Regardsm
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
If you don't have the add-in, do a Revolve cut to remove the parasolid fillet then Fillet the newly created edge.
Scott Baugh, CSWP
FAQ731-376
Make a copy of the model so you can go back and check the original fillet faces after they are deleted.
