eDrawings - offset sections?
I've had trouble with eDrawings where either the section of an assembly shows up slightly off center.  This has happened twice, once with a assembly that I used the section tool within eDrawings, and the other time when I made a cut on the assembly, created a drawing and then published an eDrawing.  I sent the file to a vendor, and he pointed out the problem.
Anybody else seeing this?  It's eDrawings 2004, I'm running SP 3 on SW2004.
