My pet peeves with SE v15!
When you have the main assembly open and go to edit a sub assembly why can’t you select a bunch of parts using a window to hide or what ever?
It works in the highest up assembly that you have open but not a sub assembly. To me this is very annoying!!
When you are in Draft it is very difficult to dimension a hole using hole callouts when the hole intersects with another hole.
Why can’t you create a hole in a part that has the edge of the hole tangent to the edge of a part or tangent to another hole.
There are many more these are just a few that are bugging me right now.
I feel better now. Venting helps.
RE: My pet peeves with SE v15!
Because that would create a zero thickness feature, which is a no-no.
In the real world this is sometimes needed.
