Aqueous CO2 Storage
Aqueous CO2 Storage
Aqueous CO2 Storage
May someone direct me to a source of standards / regulations of Aqueous CO2 storage?
What is the proportion between stored CO2 mass and required vessel's volume?
Many thanks in advance!
RE: Aqueous CO2 Storage
Shmulik:
I always design and try to maintain a maximum Liquid CO2 to vapor space in the tank of 85%.  This "fill" ratio has proven its worth over the many years I spent with the CO2 industry.  It allows for enough variation in saturated conditions and gives sufficent cushion for the vapor space.
I've used this standard even while producing high-pressure liquid CO2 and expanding it directly into the storage tank for its subsequent storage at 200 - 250 psig.  The expanded vapors were separated within the vapor space and returned to process recycle.  I also use this fill ratio on transport tanks as well.  I've taken the ratio as high as 90% on large and well-instrumented plant storage tanks - but I always install redundant level alarms just in case, to be safe from an over-fill or a liquid return through the vapor balance lines.
You cannot afford an unexpected pressure relief device to go off on a liquid CO2 storage tank.  If the valve sticks open with dry ice under the seat, the tank can relieve down to atmospheric pressure and the subsequent liquid/dry ice temperature within the tank resulting from the relief will damage the quality of the tank steel to the point that you will have to destroy it - a very, very expensive lesson to learn!
Art Montemayor
Spring, TX
Shmulik:
In the previous post, I assumed you meant to say "saturated" CO2 - not "aqueous" CO2 (or carbonated water),
Art Montemayor
Spring, TX
