Anyone know how how to grey out a macro icon?
I would like to grey out my macro icons when they are unavailable to certain areas? For example if I have an icon that performs assembly operations I would like it greyed out during drawings.  I know I could just put it in the assembly toolbar but would like to do this instead so I can group all our custom macro icons in one toolbar.
Anyone have an answer?
RE: Anyone know how how to grey out a macro icon?
You could create groups of your macros, Assembly, Part, etc, then just include those in their respective toolbars.
from (the City of) Barrie, Ontario.
Everyone has a photographic memory. Some just don't have film.
You could also do a check when the macro starts to determine if the current active document is what it is suppose to be.  If not, have a gentle error message tell the user that the macro cannot be run, then end the macro.
If your macro is specific to a document type, add a few lines of code to the beginning of your macros to detect document type.  This is prudent in all SW API programming.
An example of testing for document type would be:
Sub main()
    Set swApp = CreateObject("SldWorks.Application")
    Set Doc = swApp.ActiveDoc
    If ((Doc Is Nothing) Or (Not (Doc.GetType Eqv swDocDRAWING))) Then
        Msg = "A drawing document must be active to use this command!"
        LongStatus = swApp.SendMsgToUser2(Msg, swMbWarning, swMbOk)
        End
    Else
        Doc.PrintDirect
    End If
End Sub
