Chamfer Along Portion of Edge
I have been messing w/ trying to make a chamfer that only covers a specified distance along an edge. The chamfer tool doesn't seem to facilitate this, and I cannot use the sketch chamfer tool b/c the chamfer is on an edge created by an extrusion process.
The closest I have come is to sweep a triangle along a path that covers the portion of the edge that I want to chamfer, however, the edge details are a little crude compared to how I think that SW would do it if SW can do it.
Thanks in advance,
Brandon
Thanks in advance,
Brandon
RE: Chamfer Along Portion of Edge
.....Peter.....
I use the same method as you. An alternative would be to make an extruded feature, then add a chamfer (or include the chamfer at the sketch level), then make another extrude which does not have the chamfer. Not a nice clean way, but a possibility & you would then be able to control the chamfer length by controlling the first extruded feature length. (By DT or manually or equation)
Another possibility I have not tried is to use multibody parts ... one with & one without a chamfer.
That was the first thing I tried. I could not get it work for me ... the chamfer continued through the split edge. If you have done this please post how.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I get the same problem w/ split lines that CorBlimeyLimey pointed out. So I tried splitting the chamfer after I created it, which worked, but now how do I get rid of the parts of the chamfer that I don't need w/o deleting the whole feature?
BTW what did you mean by "the edge details are a little crude compared to how I think that SW would do it"
