VBA WebBrowser Disables F2 function.
I have created a VBA program that uses the Webbrowser add on to display technical information inside AutoCAD. When I run the program it disables the "Graphscr" portion of the F2 key. If I open the program in the Visual Basic editor and then close it again. The F2 key function is back to normal. Is there anything that I can do to correct this problem?
