how to make the user toolbars dockable
I would like to make the user tool bars dockable in UG, any help would be greatly appreciated.
RE: how to make the user toolbars dockable
Any help is appreciated.
thank you
Docking can be a bit tricky. Sometimes you need to drop the toolbar to be docked at the upper right hand end of an existing docked toolbar BEFORE it will snap into the desired row. Other times, you need to drop the toolbar at the lower right hand end.
If your existing docked toolbars are pushed off screen, then you need to dock the toolbar in a second row by dropping the toolbar above or below the existing docked toolbars.
I hope this helps.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
You need to make a toolbar with an *.tbr extension.
Copy one of those in the UGII\menu folder and edit to see what the format is.
I used to use the "user tool bar" a long time ago (v16)
but learned how to create the tool bar *.tbr from forums such as this.
This is what I founf on UGNX documentation. I did a search for "user tool" and its on the gateway location
"The User Tools toolbars are no longer dockable."
