sewage sludge pumping
I'd like to develop an excel spreadsheet on sewage sludge pumping systems.
Could anyone help me with the procedure/calculations to follow in such a excercice (viscosity, laminar/turbulent flow,............)
Thanks.
Thanks.
RE: sewage sludge pumping
The sludge will vary depending upon whether it is primary or activated sludge, the degree of solids, polymer addition, temperature, shear rate, type of pump used and % screenings.
Try the AWWA website. books by Metcalf & Eddy, USEPA website and the WRc in the UK for data.
AFT's software Fathom can model Non Newtonian fluids such a sewage sludge however you will need the base data for the power law or Bingham fluids parameters.
I'll investigate and send some more references later...
1) Manual of Practice 20 Sludge Dewatering Water Pollution Control Authority ISBN 0-943244-42-0.
2) Sludge Treatment Plant TR 189 Water Research Centre (UK)
3) How to Design Sewage Sludge Pumping Systems TR 185 Water Research Centre (UK)
Also contact Mono (UK) and Seepex(Germany) as both have experience of pumping sewage sludges using progressive cavity pumps.
