Tube routing from external data (V5)
Hi!
Does anyone know how to use the scripting functions such as
addRun (and similar) to get them working?
I´m trying to create a tubing route from external data but the VB/Catscripts examples in the CatiaV5(R11) documentation does not work. When trying to add node coordinates using addRun (an ArrangementRuns method), the script is failing in both VBScript/CatScript and VBA.
