ôfair weatherö and ôpmf/ severe stormö
I am looking for a clear and concise definition for “fair weather” and “pmf/ severe storm” analysis, as it pertains to dam breach analysis. (Especially with respect to initial conditions and assumptions).
RE: ôfair weatherö and ôpmf/ severe stormö
PMF or severe storm assumes failure due to overtopping, inadequate spillway, erosion caused by extreme flows through the spillway or outlet works, structural failure due to high water levels etc. Flows in downstream spillway channel or inundation area are assumed to be quite high due to the presence of the severe storm.
Generally, the depth of the flood flow during a pmf breach is higher than a sunny day, however, the sunny day failure often causes more loss of life and property, because it happens with very little warning. The PMF breach may only cause an incrementally small increase in the downstream water levels if the downstream area is already inundated due to the extremely heavy rainfall.
