which weld spec would you recommend???
Hello All,
I work for an oceanographic weather buoy company. These buoys are usually required to be light weight (thin wall aluminum) which in some case welds are required which are small i.e. 1/16". We have a reputable weld shop that we have used for 20 years. Now we have a customer requesting/buying the drawing package for one of our products, but they want us to reference a weld standard on the drawings. Here in lies the problem, do we reference MIL-Spec, AWS or something else, but most of these standards we know we are stretching the spec (structural) vs. what the welded joint is (in our case a seal that we pressure test for leaks) really used for. I do not want to reference a spec just to get the job done.
Tofflemire
Tofflemire
RE: which weld spec would you recommend???
