adjustable assembly in dft file will not display correctly
asm 1 -> adjustable cyl
asm 2 -> assembly containing (2) of asm 1
in the asm 2 file asm 1 works fine display i correct
in the dft file for asm 2 asm 1 displays as it does in the asm 1 file rather than how i have them set in the asm 2 file. this is the first time i have tried using the adjustable assembly if i change asm 1 back to a rigid assembly asm 1 display is correct... asm 1 is attaced to (1) stationary clevis and one on a pivot. ... any hints?????
