WHERE TO LOCATE A PRESS ACTUATED WATER REGULATING VALVE
Hi all ,
As ever I see , when puting a regulating flow valve it is done downstream the condenser , or heat exchanger.
As the usually used GLOBE VALVE , it run too when regulating the pump flow.
For a PRESSURE ACTUATED WATER REGULATING VALVE.
There is any reason a valve vendor state it as follow:
"Mount vertically with elbows down, ON THE INLET SIDE of condenser.""
Pardal
