catia launch with part
hi,
when ever i start catiaV5 it always starts with product workbench. is there any way to change it to part or any other work bench or a blank one.
Thankx in advance
V5Starter
Thankx in advance
V5Starter
RE: catia launch with part
I found this link in my notes:
http://www.d-digest.com/catiadigitaldigest/v3i44/tipsntricks.html
Somebody put on another forum these variables with short description (I think these are the same like in the link already put by jackk)
CATLM_ODTS=1 - Disable license error messages at startup
L_WILSON_LAN=1 - Access to Wilson's spline curves
CGM_ROLLINGOFFSET=1 - Access to the Rolling Offset option in GSD
TAILLE_MEMOIRE_CHOISIE=1 - Optimize IGES export memory
CATNoStartDocument=no - Disable product at startup
CNEXTBACKGROUND = no - Disable sky background at startup
CNEXTSPLASHSCREEN = no - Disable display of planet at startup
SHOW_CST_CHILDREN = 1 - Display stresses in the parents specification tree in sketcher
CNEXTOUTPUT = console - Display Catia's logs in command windows
MM_NO_REPLACE = 1 - Associativty about replacement of components cloned with different
You can put all of them if you are going to control panel-system properties-environment variables-add new user variable.
Fernando
"C:\Program Files\Dassault Systemes\B13\intel_a\code\bin\CNEXT.exe" -env CATIA.V5R13.B13 -workbench "Part Design"
This command was found on the CATIA help file in the Infrastructure User Guide/Starting a session on windows. Similar options can be set for UNIX also.
Steph
