False advertising with regard to expired state PE
Let's say someone has a website that indicates thay have PE license in 5 states, for example Connecticut, New Jersey, New York, Pennsylvania, and Texas.
Check with Texas PE website indicates no record this person is registered. http://www.tbpe.state.tx.us/cgi-bin/NewSearch/get.cgi?db=rpe
It might be that their TX PE has expired, I don't know.
Is this just a minor inconsistency, or a breach of PE ethics?
RE: False advertising with regard to expired state PE
Had he had a lawsuit during that time, he would have been up a creek. It pays to check up on your board's website to make sure your status is as it should be.
--Scott
For some pleasure reading, try FAQ731-376
Texas's web site stays pretty current, but errors can occur. Contact them directly (512) 440-7723 if you think there has been a breach. If you are licensed in Texas, the Board rules now require you to notify the Board. Failure to notify is itself an infraction of the rules -
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
