Transformer Data Sheet
Any body knows from where I can get transformer data-sheets (in Table format)?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Transformer Data Sheet
Try
http://www.eatonelectrical.com/NASApp/cs/ContentServer?pagename=C-H/Common/AssetTemplateLink&c=Apubarticles&cid=982605102190&Sec=products
The transformer tests are performed per industry standards, e.g. ANSI/IEEE Series C57. Visit
http://www.ieee.org
http://www.ansi.org
for more info
There are various sources of generic transformer data giving kVA, voltage impedance, load / no-load power losses etc
Tranformer manufacturers such as Schneider, Startkstrom et al usually have such info on their web sites.
_______________________________________
Regards -
Colin J Flatters
Consulting Engineer & Project Manager
If you are preparing a design however, then generic data is all you can go on, however there are differences in transformer design which you need to consider eg, is it ONAN, AN, ANAF .....
Manufacturers data on web sites will give typical voltage impedance, power loss and noise levels etc, as well as dimensional data.
For Brush transformer, try the following
http://www.fki-et.com
Regards -
Colin J Flatters
Not quite sure I get your point ?
As far as UK projects are concerned, the transformer specification is generally defined in terms of the technical requirements and referenced to IEC 60076 standard.
This leaves the tender open to competitive tender unless there are reasons to specify a particular manufacturer / product range. The enquiry document is a contractual document.
The differences between typical quoted impedance values and final measured values on the test certificates are negligible.
NB - We do not undertake in 'wild west' tactics or corrupt tendering practices.
Regards -
Colin J Flatters
There is very little it can be done about cowboy's bugs in the software, or corrupt files.
