dryer efficiency
dryer efficiency
What would be the best way to define and calculate dryer efficiency, specifically the efficiency in a fluidized bed dryer??
RE: dryer efficiency
m777182
Efficiency = Heat input/ heat output
Heat input = mass flow rate times enthalpy difference of leaving air and entering air.
Heat output = mass flow rate times enthalpy difference of steam and condensate(presuming steam drying).
This gives the efficiency of the dryer with respect energy. If you want to check with respect to process, you should know the moisture content before and after drying. That is all.
Eng-Tips.com : Solving your problems before you get them.
