Stress Releiving Calculations
is there a standard/generic formula/table for calculating stress releif after welding?
thanks in advance
thanks in advance
Stress Releiving CalculationsStress Releiving Calculations(OP)
thanks in advance Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Stress Releiving Calculations
thanks
You could also use AWS D1.1 Structural Welding Code post weld heat treatment guidelines, as well.
Further you may refer to ASME/ANSI B 31.3 for the same data for Piping.
Yes there exists a formula which acts as the basis of the Time Temp table. I had it noted down from one of the ASME but don't recollect from where i got it. I think it is in ANSI B 31.3.
Good Luck
Tp = T*(20+ Log t)/1000000
T = T in Centigrade + 273
t= Hours
For change in PWHT Temperature, how much shoul be the change in soaking time?
Equate Tp and solve to get the soaking time t.
Good Luck
Tp is the Tempering property
Please advise me about the reference of the formula. Can we use this formula for all materials?
By using this option (Higher soak at lower temp) (if you have not (Welding Engineer) planned) after commencement of fabrication, you may land up in PQR related troubles (Especially if the Vessel is in Sub zero service)
Not discouraging you, but giving you the pit falls. About 4 months back i remember there were discussion on this subject (Supporting PQR).
By proper planning (By welding engineer) this can be amicably settled.
Good Luck
C-Mn Steels (P. No. 1, Gr.1 or 2), Thickness<2”, Initial residual stress = 40,000psi
Remained Residual Stress After PWHT [Reduction Rate]
0 psi [100%] after 2 hours @ 1400 F
1,200 psi [97%] after 1 hour @ 1400 F
3,000 psi [93%] after 4 hours @ 1300 F
3,500 psi [91%] after 2 hours @ 1300 F
4,700 psi [82%] after 1 hour @ 1300 F
3,000 psi [93%] after 16 hours @ 1200 F
4,000 psi [90%] after 12 hours @ 1200 F
5,000 psi [88%] after 8 hours @ 1200 F
5,800 psi [86%] after 4 hours @ 1200 F
6,200 psi [85%] after 2 hours @ 1200 F
7,200 psi [82%] after 1 hour @ 1200 F
7,000 psi [83%] after 8 hours @ 1100 F
7,700 psi [81%] after 4 hours @ 1100 F
8,000 psi [80%] after 2 hours @ 1100 F
9,000 psi [78%] after 1 hour @ 1100 F
8,000 psi [80%] after 8 hours @ 1000 F
9,900 psi [75%] after 4 hours @ 1000 F
10,800 psi [73%] after 2 hours @ 1000 F
12,000 psi [70%] after 1 hour @ 1000 F
Please use this only for reference by lab test
Thomas Eun
Can you post the Holloma-Jaffe formula please.
I apologize for letting you wait that long. I didn't see your request earlier. The formula is based on L/M. It is Hollomon and Jaffe formula:
(T+273)*(20+log(te))
HJ = -----------------------
1000
te = th + tc + t
T+273
th = ---------------------
2.3*h*(20-log(h))
T+273
tc = ---------------------
2.3*c*(20-log(c))
Where:
HJ - Hollomon/Jaffe parameter
T - holding temperature [°C]
te - effective holding time [h]
th - correction in holding time for heating cycle [h]
tc - correction in holding time for cooling cycle [h]
h - heating rate [°C/h]
c - cooling rate [°C/h]
The formula was derived empirically and it seems to reflect better the effects of heating and cooling on tempering degree of metal than LM parameter. I used this formula to asess the remaining life of pressure vessels after multiple PWHT cycles. It was also used to set the parameters of PWHT simulation cycles.
JacekM
