Equivalent Radius of Helical Handrail
Does anyone know an equation that calculates the equivalent radius for a helical handrail on a set of curved stairs?
Discover the role technology plays in supporting transformation and the importance of Engineering and Manufacturing collaboration
Download NowINTELLIGENT WORK FORUMS
RE: Equivalent Radius of Helical Handrail
If so, then the equation for Curvature K = r / (r^2 + c^2) can be used, where r is the radius of the cylinder that the helix lays on and c is the pitch. As Curvature is 1/R then the Radius of Curvature,
Rc = ( r^2 + c^2 ) / r
As the handrail is a space curve the Radius is rolling over as it moves along the helix, and as the pitch and cylinder radius are fixed the Torsion of the curve is constant.
Development of the helix is a right angled triangle where the hypotenuse is the true length of the curve, the other two sides being Pi*D and Pitch respectively, or multiples of according to the number of helical turns.
where:
1/r = curvature of the helix
r = ideal inner radius of annular strip
R = radius of cylinder
H = height of one turn of the helix (2Pi radians)
Would this also give you the equivelent radius?
Referenced:
http://ww
