autostack dialog box
hi;
How do you bring up the autostack dialog box? I want to remove the autostack default from my mtext, but not dimension styles.
thanks,
sundemon
thanks,
sundemon
RE: autostack dialog box
However, even after all this, I'm not so sure you can achieve what you are tying to do, because even the dimension just uses mtext. So I bieleve it is all or nothing. I could be wrong though!
Chris
that did it. BTW, this didn't have an effect on the stackingh in the dimension style.
sd
The fraction stacking option for MTEXT is as described above.
