Calculating elongation of bolt, at thread engagement?
In order to ensure that the proper bolt preload is achieved, I have calculated a corresponding bolt elongation using the following formula:
Total Elongation = sum of [(PxL)/(AE)], at various cross sections of the bolt.
I found that the actual Torque value was less than what I estimated it would take to achieve the desired elongation.
In the above formula, does the entire nut thread engagement have equal tensile load through the entire nut thickness?
(consider "L" = nut thickness?)
RE: Calculating elongation of bolt, at thread engagement?
When using the equation for screw stiffness, the effective nut height is assumed to be d/2, where d is the nominal screw major diameter.  If you need a reference, it is on page 183 of Handbook of Bolts and Bolted Joints edited by Bickford and Nassar.
Cory
