Interior Partition Wall Pressures
What kind of pressure difference do y'all get for interior partitions? I have one storey community club & gymnasium project with a 2x8 bearing wall 18 ft high, picking up a fair bit of roof load from two spans, but the wall is interior. I am trying to verify that the combined axial load and lateral bending is not exceeding the stud strength and I am close to the max.
Our code (Canadian) seems to say that the pressures we should use would be the pressure differences between the windward and leeward sides of a building which amounts to about 3 psf max according to my calcs. Does that sound about right?
RE: Interior Partition Wall Pressures
I am familiar with the 5psf interior wall load requirement in the UBC, but I have not been able to find a similar requirement in the IBC 2000. Can you provide the section where this is listed?
jt
