About X10CrMoVNb9-1 (EN 10222-2 )
Hi!
My question is short and simple: To what material group does X10CrMoVNb9-1 belong.
The material is not listed in either EN-1092-1, ISO-7005-1 or prEN-12516-1 so if someone has any bright ideas, I would apreciate the help
Pontus
Pontus
RE: About X10CrMoVNb9-1 (EN 10222-2 )
Other than that I'm of no help.
Nick
I love materials science!
For example:
P265GH belongs in group 3E0
13CrMo4-5 belongs in group 5E0
10CrMo9-10 belongs in group 6E0
So ewhere does X10 fit in?
1,4903; 0865 bar
Spec VdTuv 511/3
Also under CR ISO 15608: Material Gr 6.4 for forgings
EN 13445-2:2002 Issue 6
Also En10216-2
Sorry about the lack of uniformity as I am not that familiar with EN specs. This just a copying from tables with small print.
The grade you mention is listed in the SEL 2000 and is WNR. 1.4903
Its also listed in the DIN EN 10302:2002:09 ann the DIN EN 10028-2:2003:09
Best Regards
Richard Buss
To what group it belongs can not be answered because you do not specify the purpose or Code you refere to.
E.g. for welding qualification per EN 288-3 the group will be 6.
As I mentioned in my original post, X10 is not listed in either EN-1092-1 or prEN-12516-1 (which are the ASME counterparts)
