Non toxic material
Non toxic material
Non toxic material
Hello everybody,
I have to select a few plastic material to be applied in an alimentary used machine. The FDA certification is not needed for the element that are not in contact with the food. But in any case I have no database to check if a material is suitable for alimentary use. Are this information available on the web?
Thanks in advance
RE: Non toxic material
Have you tried www.matweb.com this website offers a huge range of material info. including plastics
Here's two plastic that I can recommed they are both FDA approved:
PETG Copolyester this is a tough thermoplastic with high impact strength and very good optical clarity, it also has very good chemical resistance
Tensile Strength 53MPa
Young's modulus 2100N/mm2
Acetal Copolymer(POM)
Tensile Strength   65 MPa
Young's modulus  3100N/mm2
A high strength and rigidity offering good sliding properties, resistant to dilute acids etc.
I obtained this info. from RS's engineering material section, you could try contacting your plastic supplier or contacting RS here's there web address rswww.com
Bry
