Different Curve and Surface types
I have a question some of you probably know, yet after looking all over for answers I have come up short. What is the difference between Cubic and Quintic curve fit methods? What is the difference between plane and B-surface Free Form Construction Result, and also the Polynomial Cubic Surface? I was having trouble with IGES (go figure) and found that exporting Polynomial cubic seemed to come in cleanest, and I was unable to figure out why, and this leads to me wonder what the differences between curve and surface types are, and the advantages of each. Anyone?
Cheers
RE: Different Curve and Surface types
It requires a math major to explain it. The basics are that most CAd systems use ther own definition of a spline a nd surfaces. By using NURBS, the math definition is defined by some french mathematician. The different types of splines and such determine the curvature/slope of the resulting geometry.
The higher level curvature will work better in an IGES translation because the formula is now the same on both systems.
DISCLAIMER: I am a mfg engr by degree. I may be totally off the wall on what I said above.
Quiz Time: Define STRESS.
To a mechanical engineer, it is the amount of bending a piece of metal can withstand before reaching its yield limit.
To a manufacturing engineer, it is getting the next MC tape to the shop floor before the current job is finished.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
