Vibration isolator vs Vibration damper
Guys,
What is the difference between a vibration isolator and a vibration damper. Any specific example.
sltg
thanks
RE: Vibration isolator vs Vibration damper
SLTG
I have'nt had a lot of experience with vibrations of any great magnitude, but I did design a platform holding large (20000cfm) exhaust fans.  The fan mounting bases came with springs which dampened/isolated the fan vibration from the platform.
I would say that it is a matter of terminology whether you dampen or isolate the vibration.
Haggis
if you're damping the vibration, you're dissipating the vibratory energy.  If you're isolating the vibration, you're preventing the vibration from being communicated from one part of a structure to another.  Isolators will often have some inherent damping (like rubber mounting feet), but in most cases the damping actually worsens their ability to isolate, by increasing the transmitted vibratory force.
SLTG
Check out Thread384-90703
